$175 Class D amp--120 wpc
0 Members and 2 Guests are viewing this topic. Read 1219605 times.
srb
Re: $175 Class D amp--120 wpc
« Reply #720 on: 8 Mar 2010, 07:33 pm »
I tend to disagree.  Have you looked at my gallery?  If not, take a look at my sub that I made.  There is A LOT more then that in material (6061) cost.  If you were to then add my design, machine and assembly time, that's how you get REALLY expensive gear.  Of course, that's without the $50k per month TAS ads.
The Pass enclosure does not have a comparable materials and machining scope to your subwoofer.  It's a steel chassis with some overly hefty CNC machined front panel pieces, and an over-the-top example at that, which I probably shouldn't have picked.
In the context of average "high-end" components, I was merely refuting the comment that "up to 70% of the ultimate retail price of hi-end components is due to the cost of the cosmetics", although it certainly adds to the cost.
avionic
« Reply #721 on: 8 Mar 2010, 07:39 pm »
Hope this is legal:    http://www.audioholics.com/education/amplifier-technology/clone-amplifiers
The class D amps sound great,especially for a couple hundred bucks. You also get the knowledge and pride of building something on your own. As far as parts for assembly you can go as cheap and cheerful or as exotic as you want making your amp the way you want it.
firedog
« Reply #722 on: 8 Mar 2010, 08:08 pm »
The audioholics article links to this: http://www.hificritic.com/downloads/Class-D.pdf
which basically claims that ClassD amps, by definition, aren't even real hi-fi and can't sound good.
Interesting b/c lots of critics and experienced audiophiles have reacted to many of the recent examples saying how "surprised" they are and how "good" they sound. Shouldn't the "ear" test be more important than the "theory" test?
jtwrace
    • TIPP YouTube Channel
« Reply #723 on: 8 Mar 2010, 08:09 pm »
YES, but data is fun to look at.   :)
Mariusz
« Reply #724 on: 8 Mar 2010, 08:10 pm »
Guys
lets keep it on topic.
I certainly won't tolatate bashing other brands on this circle ( not that it happened but it might turn into a pig fight.  We do not want to do that. Unless you want this thread locked.  :scratch:)
Thank you
Regards
Mariusz :thumb:
jtwrace
« Reply #725 on: 8 Mar 2010, 08:12 pm »
Thank you
Regards
Mariusz :thumb:
No sir!
pjchappy
« Reply #726 on: 8 Mar 2010, 08:16 pm »
I would love to see data on the on-topic Class-D modules. . .even though I would probably have no clue what most of it means. . .   :lol:
Paul
mjosef
« Reply #727 on: 8 Mar 2010, 08:35 pm »
Ummm...hope I am not seeing a sorta theme evolving here, where any dissenting views on the sonic quality of these modules are subject to ridicule and overbearing arm wrangling. That will be a shame since this thread is now over 35pages, however when something has come such a long way there may be the tendency to be over protective.
I have been offered one of these amp module for a home demo, and hope I can post whatever impressions I have compared to what I am currently using which is nothing fancy, a modified Adcom 555II.
The proof is always in the pudding, or tasting thereof.
wushuliu
« Reply #728 on: 8 Mar 2010, 09:00 pm »
Actually I think we just spent more time on retail manufacturing/cost ratios than on any dissent. There's a lull right now so before the mob gets angry you'd better get on that demo right quick! And it better say what I want it to say or  :uzi:!
I suggest 80 proof in that pudding.
jtwrace
« Reply #729 on: 8 Mar 2010, 09:03 pm »
I gotta say that I use 300 wpc Class A mono blocks as my reference amp.  These Class D amps are really good.
Like anything in this hobby, it comes down to YOUR preference.  In my opinion, you can't go wrong with these amps.
Yes, they're that good!  Again, starting at $175.   :duh:
pjchappy
« Reply #730 on: 8 Mar 2010, 09:06 pm »
Are there any published specs on these modules that I may have overlooked, other than the brief power ratings, etc. on the site?  I've got a kit ready to go. . .again, I'm just curious.
Paul
konut
« Reply #731 on: 8 Mar 2010, 09:10 pm »
This article was dated 2008. Most, if not all, of the objections raised have been overcome. I cannot speak directly to the amp boards that are the subject of this thread, suffice to say that the Hifi Critic article paints with so broad a brush as to be almost totally useless when discussing specific designs subsequent to its publication.
wushuliu
« Reply #732 on: 8 Mar 2010, 09:13 pm »
Paul
I believe links have already been provided for the IR-based amps. Since these amps are basically equivalent to the evaluation boards, that should be a source for measurement data.
I imagine it's the same for the TA5630 boards (correct me if I am wrong):
http://www.irf.com/technical-info/refdesigns/iraudamp7d.pdf
http://focus.ti.com/lit/ds/symlink/tas5630.pdf
dewardh
« Reply #733 on: 8 Mar 2010, 09:14 pm »
Aren't these the same critics who said the 3886 wasn't "real hi-fi" (until someone put one in a $2000 box and it became "the best of the best" ? ? ?)
Possibly amusing aside . . . I'm using gutted Adcom 535 II boxes (bought cheap with blown outputs or transformer fuses or whatever) to house my classD amps . . . and gutted 535 boxs (with 4 channels of output connectors already installed) for my 4 channel 3886 amps . . . and note that a 2535 box would work great for two of the 250x2 boards using the existing transformers and ps (with some added filter caps).
wushuliu
« Reply #734 on: 8 Mar 2010, 09:19 pm »
I hope some more folks try replacing the input caps as it's pretty easy. Should have taken pics but I forgot. Got too excited...
Nick77
« Reply #735 on: 8 Mar 2010, 09:22 pm »
What kind of results are you getting? Was that just some basic .22 film caps?
Mariusz
« Reply #736 on: 8 Mar 2010, 09:27 pm »
Maybe someone else did or is wiling to do that??? :wink:
Thanks guys
Mariusz :D
avionic
« Reply #737 on: 8 Mar 2010, 09:33 pm »
Those things are tiny. Did you remove the old ones and if so how hard was it to get them off the board.
pjchappy
« Reply #738 on: 8 Mar 2010, 09:38 pm »
From a technical standpoint, anyone have any concerns based on these specs?  I am just totally curious.
Paul
pjchappy
« Reply #739 on: 8 Mar 2010, 09:57 pm »
Has anyone had a chance to compare this amp to one of the Peachtree Audio amps, the Nova or Decco 2?  I realize that everyone is comparing these to much more expensive units, but this seems to be to be a rational comparison since the both utilize class D amplification in a similar wattage and price range.
Ed
The Peachtree amps are A/B, not D.
Paul
