0 Members and 2 Guests are viewing this topic. Read 1219237 times.
I am fairly new to this site also (been lurking for awhile).I have the 250x2 500x1 amp driving my Mini Statements, the sound quality IMHO is excellent.I had an Emotiva LPA-1 before I decided to assemble my own amp, and this classD amp is easily it's equal to my ears. My wife, who has better hearing than I do, says the class d sounds better.Here is my mix and match amp, it was originally 4 TDA8924 modules 3 bridged 1 stereo for 5 channels, now 1 classd 250x2 4ohns and 2 TDA8924 modules for 5 channel.
Sounds as if I made a good choice. I like what you have done. This amp will be for two channel only ,however, if all goes well I may put together a three channel setup to power the front end of my HT setup. My Speakers
The amp went into shutdown listening to rock.I am thinking about adding a bigger heat sink or fan.
I have been using the Ebay case and if I take the cover off the ampdoesn't shut down. The heat sink was extremely hot - untouchable.So I think I will put a quiet Papst fan in their.Can I pick off 12v for a fan off the board somewhere?Jeff
It appears that you could remove the orange SMD caps, solder a jumper across the pads and then series the new cap between the RCA input and the positive through hole connection of the removed terminal block. I haven't tried it but it at least apprears to be doable.
Well I jumpered the orange smd's and put 22uf dayton/jantzen caps in series w/ input. I'd say there's some improvement (some harshness but I'm sure that'll go away) but unfortunately I also put in a modded ebay dac and am so wowed by that it's hard for me to say how much a difference these new caps have made.Upside is it's pretty easy to pop out those smd's and try it out for oneself. Only took a few minutes.
X2yeah, any links?I was looking at few ready boards (upsampling and NOS)but can not decide which one to try. THXCheersMariusz
I can start a short thread with some pics, as I don't want to take this off topic...
Hmm. surprised it's that warm...
Is it exposed to the air, enclosed in a case or have a fan?Does yours run only warm under a load?Thanks!
Are other boards not running hot? Maybe mine has an issue.
