0 Members and 5 Guests are viewing this topic. Read 1218835 times.
Anyone put a volume pot on theirs?
Pumpkin that looks very cool, curious about what your costs will be?
After reading some of the posts it seems that an all wood cabinet is not the way to go that's why I went to the sheet metal shop.........
Pumpkinman, You either have a friend at the metal shop, or got lucky and found one that is uber-reasonable, but I think the majority of us would have trouble finding a shop that would cut and bend an aluminum back panel for $3.00 or a chassis for $15.00! Steve
I suggest you ask Tom this directly. He's very responsive to emails.
I have no doubt that a competent metal man could make a chassis in 15 minutes. But I still think that the charge would normally be more than $15.00, and to have someone do anything to a piece of metal for $3.00 out the door is incredible! So, if anyone else has a custom chassis made for them, please report back and let us know what you got and what you paid. Steve
These amps are easy to drive, so a volume control will work perfectly. There is no need for an active preamp. Actives still work well, but you will find less travel in the volume control.
I thought a circle in the center w[h]ere the switch will be would look good the center will [be] orange in honor of all my pumpkin brothers
If the amp works laying on a board, why wouldn't it work fine in a wood enclosure?But, what do I know?
It works fine in a wood enclosure, but . . . not the best in terms of minimizing RF generation
Maybe you could find a painter who isn't a friend and does lousy work, so that the end result will have plenty of "orange peel". Steve
Exactly so . . . and the cost of EMI compliance/certification is probably part of the reason there is no assembled product or even complete "kit". As it is the responsibility for emission control lies with the individual builders.
