0 Members and 5 Guests are viewing this topic. Read 1218766 times.
Maybe once my build is done we can do what Audiokarma (aptly) does for some gear and send it around to different people to try out w/ their own classdaudio amps and pres and report back (it's light and should easily fit in a Priority medium flat rate box).
I would be glad for an opportunity to hear the amp on tour. The reason being that, over the past three years, I bought several amps that were highly touted in the audio press and in forums, including tripaths and tubes. I no longer have any of those amps because my 25 year old Cary 807 surpassed them by far. In other words, I've misspent my meager audio budget, several times, and I do not want to repeat that unsound exercise.
When I asked Tom at Class D Audio to compare the TI amp to the IR amp as far as sound quality, the reply was: "The 600W amp is the TI chip and sonic quality is not as good as our other amps with the IR chip. Our IR based amps are some of the finest sounding audio amplifiers on the market today. The TI rating of 600W is actually at 10% distortion, so our 250W X 2 4 ohm, 500W X 1 8 ohm is actually rated full power at 1% so actually are more powerful. Our IR based amps are more powerful than people think and all are surprised when they listen to them. The actual distortion levels of these amps through almost all of the power range is more like .006%.... very good!"Steve
This thread has me thinking of trying the 600W module, mainly since its touted as stable into 2ohms, and my bass section is just under 4ohms. Plus I have found that there is no substitute for power when it comes to bass. I currently biamp, with a crossover point @ 320Hz.
The Primary Election in Texas is over and my client won. Now I get to move on to the really exciting stuff when my extra parts arrive...probably on Friday. Anyway, here's what I have so far and I'm looking forward to wiring this puppy up and hearing what it sounds like.
Looks awesome, i think you will be impressed. Are you still running the single driver speaks?
So it would seem the only reason one might choose the TI amp is to either drive a load of 2 ohms to 4 ohms in stereo mode or a 4 ohm load in bridged mode? The description says "with a power stage designed to drive 2-Ω to 8-Ω speakers at up to 300 W per channel in stereo, or up to 600W bridged". It doesn't mention the impedance range in bridged mode, but I would assume that it would be limited to 4 ohms in bridged mode, whereas the IR-based amps would be limited to 8 ohms in bridged mode? Steve
I'm the one that originally mentioned the 3k input impedance in this thread. The measurements from which I derived that input impedance are on page 13, and I'm quite certain the input impedance of my amp is ~3k ohm. Also, as wushuliu stated, 3k is the value given in the spec sheet for the amp (also posted by me on page 13), and others on diyaudio have stated the input impedance is 3k. I would be very curious to see Tom's measurements demonstrating an input impedance of 45 k or to know if he's made changes to the amp since I ordered mine.
To clarify this, I asked Tom and he indicated he has modified the input impedance on his amps to be more compatible with more preamps on the market. It is indeed now 45K ohms. Here's a quote from Tom:"I’ve modified the input impedance to 45K. Also lowered the gain. I’m trying to make them more compatible with all equipment. They’ve always worked with almost all preamps, but a few had had problems, so I make changes when necessary to always try to improve them. The sound quality has not changed, and it’s something most would never notice, unless of course they were one of the few that had a preamp mismatch."steve
Perhaps you can ask Tom exactly what he has changed? The boards I have follow the IR reference amp almost exactly (although layout is different to accomodate the smds, and part numbers are changed, which makes circuit tracing more difficult). If there is going to be new input circuitry it would be nice if it were documented . . .I should note that the nominal gain of my boards is 24, and the equivalent IR reference amp has a Rin of 3.3k Ohms and a nominal gain of 30.
