0 Members and 5 Guests are viewing this topic. Read 1217945 times.
At idle the amp draws (125VAC):.9 watts.11 ampsThis is with the amp on just no music playing.
I have been lurking in the background on this subject for awhile now and would like to jump in on one unit...I would like to build a stereo unit with at least 200 watts per channel into an 8 ohm load...What do you guys recommend? I would put unit in metal chassis with switch on front and RCA's and binding posts on rear panel...Any guidance would be appreciated...TIA
My first package arrived today from Class D Audiowith the snow coming I will not have much time till the weekend...............Bill
Time to take advantage of the bad weather and build the kit out .
but the kit does not handle 4ohm load.
shadowlight - what do you mean by "the kit does not handle 4ohm load"? The product description itself is a little confusing and perhaps contradictory in this area. It states "With the included components you can build a 1000W 8 Ohm stereo amplifier or 4 channel X 500W 4 Ohm or 4 X 250W 8 Ohm. ". Do you think the kit goes into protection mode at 4 ohms?
Inspired by the Pumkin king i hit the depot and picked up a new faceplate. The bamboo i had didnt stain well at all so i swapped it out for poplar. I like it alot better as it matches the bookcase.
Tom told me he's working on a new "Super D" class of amps now.
'cause I'm thinking that we are going into this with little experience, or maybe knowledge, of how this thing sounds. I see lots of enthusiasm, myself included, but not lots of experience with the sound. Maybe it is discussed elsewhere and I don't know it. What is the basis of our enthusiasm? I know why I want one, but I would like to know more before I order the amp.
