0 Members and 5 Guests are viewing this topic. Read 1218375 times.
I received a box from Class D in today's mail. Should I open it?
Guys i replaced my Volex power cord on my 120amp with a very good diy cord. It has taken the amp to another level. I now have a level of detail and transparency that is certainly making me think twice about messing with any caps. These things seem to respond favorably to a good power cord.
I finally got everything hooked up and when I plug the power in the plastic wrapper around the transformer is starting to melt? Is that suppose to happen or did I just fry something? Currently, the way that I have everything hooked up is with a two prong plug. The left prong where the blade is wider is connected to the red wires on the transformers and the narrower prong is connected to the the black. Do I potentially have the wires flipped and that is the reason for the plastic melting.I already sent Tom a message but I figure I will try here also.Thanks
you definitely have the transformer mis-wired. it may or may not still be ok, depending on how long it was plugged in. i can't tell you the right way to wire it, but i know what happens when you wire it wrong... doug s.
Less than 20 seconds is how long I had it connected.
The blue and green wire that are CLOSEST to each other coming off the tranny should be wired together to the center terminal. You probably have the other blue and green wired together. I did the same thing.
From the pics, it looks correct. It makes sense that if the lights were on, it was correct. Tom will take care of it...Let us know how you make out when you get the new tranny.
Yep, he is shipping a new tranny on Monday. I will most likely get it Thursday, since I am in NJ and Antek is in NJ also
If it ships from NJ on Monday you might have it Tuesday...Wednesday at the latest.
I think Antek ships direct to everyone..
