$175 Class D amp--120 wpc
0 Members and 5 Guests are viewing this topic. Read 1218564 times.
macrojack
Re: $175 Class D amp--120 wpc
« Reply #220 on: 6 Feb 2010, 04:58 am »
I ordered a kit tonight. Despite the fact that I assembled a couple of Hafler DH-200 amps back in the late 70s, I'm feeling very daring and challenged about the prospect of actually making this work. I hope I know what I'm doing.
Oh well, I'm sure I've spent more money in worse ways in my past. Like the time I pissed away more than half a grand on an online real estate course. I couldn't read that crappy legal jibberish for more than twenty minutes without lapsing into a trance. Bad investment and I should have known myself better.
I've been resisting the temptation to purchase one of these amplifier kits as I avidly followed this thread. Tonight I reached a point where I could no longer ignore the impulse.
avionic
« Reply #221 on: 6 Feb 2010, 05:04 am »
You won't have any problems. If you have any questions just ask here or email Tom.
steve k
« Reply #222 on: 6 Feb 2010, 05:32 am »
It really is easy. If you've assembled Haflers this will be a piece of cake. No soldering at all in the breadboard model--just screw connections. If you put it in a case, you may have some soldering on the board and with your binding posts and RCA's but again, its relatively minor. Tom makes these really easy to assemble--all the better--you can hear it quicker that way! :lol:
steve
macrojack
« Reply #223 on: 6 Feb 2010, 05:45 am »
From looking at the pictures on his site and in this thread  I get the impression that crimp on spade lugs might be a good idea for connecting wires under the screws. I figured I'd just cross that bridge when I come to it but since we're talking, I may as well ask you guys.
earplay
  • Do ya feel... lucky?
« Reply #224 on: 6 Feb 2010, 06:21 am »
jtwrace:
The cap in question was .22 or .47uf. It's not critical, I think. I know nothing about electronics, so I took the advice of someone on AC.
You only need to separate the power lines, strip a bit of insulation off each one and attach a cap lead to the load and neutral sides. The arrangement is as if you were shorting the circuit. It seemed to me that there should have been a pop, a spark, a puff of smoke or ozone and no sound when I powered up, but it worked just like I was told.
The sonic result was that the amp had the punch and liveliness of the SMPS, but the smooth quality of a battery. That after I bought two SLAB's and a charger. For the price of a cap, a little electrician's tape and a lumpy power cord, I got better sound. Of course, YMMV, but if you don't like the result, you can just remove the cap and tape the wires.
Small investment for a really nice improvement.
Hope this helps.
steve k
« Reply #225 on: 6 Feb 2010, 06:29 am »
From looking at the pictures on his site and in this thread  I get the impression that crimp on spade lugs might be a good idea for connecting wires under the screws. I figured I'd just cross that bridge when I come to it but since we're talking, I may as well ask you guys. Logged
The photos are deceiving. The screw connections on the boards are really small. They can handle maybe one 14 gauge wire max. for each. It's easier in the breadboard model to just strip the wires and stick them in the screw connectors.
Even when I put mine in a case, I continued to use the screw connectors on the boards.
steve
jtwrace
    • TIPP YouTube Channel
« Reply #226 on: 6 Feb 2010, 12:46 pm »
Just curious what conditioner, everyday like the Belkin or high dollar?
I use an Audio Magic Nexus which is plugged into an UberBuss.
jtwrace
« Reply #227 on: 6 Feb 2010, 12:47 pm »
     jtwrace: I am looking forward to seeing your finished enclosure as well.
Me too!  I'll post when it's done....
jtwrace
« Reply #228 on: 6 Feb 2010, 12:49 pm »
No need to worry.  It's very simple to assemble and you have many peope willing to help.
jtwrace
« Reply #229 on: 6 Feb 2010, 12:51 pm »
jtwrace:
Hope this helps.
Thanks.  I'll have to check into this some more.
Nick77
« Reply #230 on: 6 Feb 2010, 01:42 pm »
No worries on this one, it worth many times its price. :eyebrows:
macrojack
« Reply #231 on: 6 Feb 2010, 01:49 pm »
That's what I'm hoping, Nick. If all goes well, I intend to replace some pricer amps with these little guys. I went for the Sony HD tuner and the OPPO BDP-83 and I'm looking for other ways to take money out of my system without cutting out it's heart and soul. So far, so good.
If my big horns like this amp, I'll be buying at least one more.
steve k
« Reply #232 on: 6 Feb 2010, 02:14 pm »
That's exactly what I was trying to accomplish. After being out of work over a year, I was looking to extract some cash out of my system without giving anything up in sound. To my amazement, my system sounds much better now!
steve
macrojack
« Reply #233 on: 6 Feb 2010, 02:26 pm »
I don't really have the background or ability to figure things out in an amplifier. Therefore, I require clear instructions in common English. So my big concern lies in whether or not the instructions are as confusing as the web site. I just bought the amp Steve recommended because it was too difficult to compare apples to apples, and because I know where I can find a picture to follow in the opening of this thread.
What is the difference between an amp and a kit?
I have an actively bi-amped system using a Jeff Rowland Capri pre-amp into a dbx Drive Rack PA. The signal is split in there and frequencies above 400 Hz go through my Jeff Rowland 102 amp to the horns. Below 400 Hz is sent through a Perreaux PMF 1850 to 15 inch woofers in vented cabinets. I'm planning to try replacing the Perreaux with the ClassD. After that, who knows? My dbx has XLR connectors so using balanced cables to the amps would be a nice bonus. For that reason, the 600 watt amp looked kind of attractive but I really don't need that kind of power since my speakers are well above 90 db efficient.
Does anyone have suggestions as to a path I might consider? Any body want my tube amps?
jtwrace
« Reply #234 on: 6 Feb 2010, 02:43 pm »
Calm down.. :)  If you can setup the dbx, I promise you'll have no issues.  Again, if you do, we're here to help.  Relax and smile lots!   :D
macrojack
« Reply #235 on: 6 Feb 2010, 03:27 pm »
Setting up my dbx is like following the footprints on Arthur Murray's dance floor.
Do I sound like that much of a basket case? Will I make it through this ordeal without medication? Tune in next week and find the answers to these and other questions.
But, while we're on the subject, I have a hissing sound. It's quiet but it's impossible to overlook. My horns are rated 108db efficiency but I pad them down in the dbx to the level of my woofs, which I would estimate to be about 95 db. The sound is like what you hear when you put a seashell to your ear. What's the problem? How do I eliminate it? Fixing that would certainly make me smile.
jtwrace
« Reply #236 on: 6 Feb 2010, 03:32 pm »
Umm.   :rotflmao:
earplay
« Reply #237 on: 6 Feb 2010, 03:33 pm »
How would these do with a passive pre? Would they be driven well with a standard DAC output level?
jtwrace
« Reply #238 on: 6 Feb 2010, 03:34 pm »
I'm driving my 600w with a Tube Buffer (Dodd Audio) and it works great!
shadowlight
« Reply #239 on: 6 Feb 2010, 03:36 pm »
I am in the same boat related to doing the build but the guys in the thread have been real helpful in providing guidance  :thumb:.  I received the boards yesterday but still waiting for the transformers.  I plan to wire up everything and take good close up pictures and post it.  Want to make sure that everything is wired up correctly before I hook it up to any kind of power.
