Now is the time iwth the case sale!!!
Sale? You mean the break for 50 quantity?
PM Sent about the sale...
I have been searching for an SMPS for the Class D audio amps for a while and finally found one. http://connexelectronic.com/product_info.php/products_id/118?osCsid=b0fbhen2sto5c1euaf4vrp4h02 Hooked it up to my CDA-254 and it sounds amazing. Even better than my modded linear power supply with 6x6800uf 63volt caps. The main reason I wanted the SMPS500R was because of the size. It is about 4"x4" , so now a reasonably sized 5 or 7 channel Class D audio amp is possible. Cristi the owner of connexelectronics is very helpful and makes a great product. Highly recommend
The DA-1 is discussed in the class d forum as is the irs amplifier here: http://www.diyaudio.com/forums/connexelectronic/ The IRS amplifier is very similar to the Class D Audio amp I believe. Please correct me if I am wrong. I don't have any experience with either.
OK, so I followed avionic's link for a power-supply, and surfing around that site came across this...Class-D Amplifier Module 300w x 2 into 8 Ohms $85.99and also this...Class D Power Audio Amplifier Module, scaleable from 2x50W up to 2x500W for $88.88 +/- depending on wattage.Anyone heard either of them?
Just got my SDS-254 (2ohm version) hooked up for a quick test. It's been a while already and I'm still "Quick Testing". I pulled out my dusty & trusty HK HD7500 cd player which fortunately has a variable out so no preamp needed...................for now my B1 build is coming.It looks pretty hacked together right now but it's not going to stay like that for long. I'm desperately looking for preferably someone local (Montreal) to drill & mill the front /rear of my chassis. I'm Looking hard at HiFi2000 case but at 30 Euro's per panel for customizations I need to find an alternative. The SDS-254 is going to replace a Mission Cyrus 1 (2nd or 3rd gen designed & built in the U.K. not the newer ones built anywhere but the U.K.). I love that Cyrus Integrated (Now in the shop) but the SDS-254 off the bat grabbed my attention with it's clarity even if it is being fed by an old HK cd player. Very impressive!Seems the hardest thing to nail down with my build is going to be the chassis...............[Update 16h later]Music to many is that flow of notes & sounds but equally important is the Silence in between. This is one silent amp & that combined with it's speed really highlights the all important silence between notes & sounds. I'm presently listening to some Marcus Johnson & really loving it. More to come!
Is that a laptop ac adapter that you are using for the power supply?
Hooked up the new to me Class D amp and was wondering if folks are using any kind of power conditioner with these. the amp sounds great but, it is located in the garage that has only one power outlet and when the mini fridge turns on and off there is a loud "pop" from both speakers when the system is playing. the fridge is plugged into the top outlet and the power strip to the bottom outlet...thoughts??
