0 Members and 2 Guests are viewing this topic. Read 1219760 times.
Jason, is the 258 a TI board or IR board? I was thinking the IR board sounded better. Is that not true? Thanks!
The IR does sound better....
Thanks, so is the 258 an IR?
Okay, quick and probably dumb question - what is the difference between the various SDS boards? Looking at the images on the site they all look the same. Voltage tolerances on the caps? Heatsinks? (though those all look the same). Maybe there are different driver chips hiding under the heatsinks? I'm just slightly puzzled as there isn't anything obvious to account for the 2x power handling diffence.Also, is the gain control simply altering the R2 value (or is it R8 maybe?) in the feedback relationship? I'm wondering whether it's possible to just jumper a resistor in place rather than use the pot - I can't imagine having those long wires picking up stray EMI would be the best idea.
Yes
I noticed your power supply has different capacitors than what's shown on the website. Care to share what you've replaced them with?
Very cool Which custom enclosure? It should work very well...
Was thinking of one of your enclosures that is featured on the Class D website. It will be mid September before I order though because we are fleeing the left coast for chilly & cheerful Minnesota.
wow - ordered Tuesday arrived Friday. Pretty good service.
Whatcha get??
Yep he sure did. I have a new amp board on the way. Hopefully by the weekend I will have good news to report. The amp appeared to be wired correctly and I was seeing normal DC levels from the power supply. The problem was the amp board, where I was seeing normal DC readings on input side, but zero AC at speaker side.I will report back when I found out what happened from Tom.
