0 Members and 3 Guests are viewing this topic. Read 1206246 times.
Hey Steve I shot you a P.M. Some people have said that the TI chip amps sound a little brighter than the IR amps. I couldn't say as I only have the IR based amp. Shadowlight you can get a pre made case for about $50.00 and the rest of the parts that you need will probably be another $50.00. Of course you could spend a lot more depending on how exotic you want to get with wiring and such. Ebay is a good source. As is parts express or parts conexxion and many others.
All of our amps are very clean and detailed, but in my opinion, our IR based amps are the smoothest sounding
Enough with the ordering, already! Let's hear about the tweaks and upgrades.
And....... does anyone knows if it can run on batteries?ThanksMariusz
That would be awesome!
I think it can be done. (I will ask around - just wonder how long will reasonable stock of batteries make this efficient amp sing? Guessing - 6h - 8h would work for most of us.)Mariusz
My Dodd Audio Tube Buffer is off the grid. I have a 28ah battery which will last 22 hrs without going below 11VDC.
I'd be especially interested if anyone can actually compare the sound of these amps to other Class D amps, as they are orders of magnitude cheaper than a "finished" product.
Enough with the ordering, already! Let's hear about the tweaks and upgrades. I'll pass this along from the diyaudio forum. The author is referring specifically to the 250W ClassD amp w/ IR chip. There seems to be an error in the initial reference to the cap value, but it is clarified later: One last recommendation for this amp: I highly, highly, highly recommend replacing the 2 .47 uf .1 uf Epcos and output filter caps (the big blue caps). I have replaced mine with the well-regarded Dayton film / foil bypass caps. Cost: $ 5. I no longer need the buffer. All the issues with this amp that I believed needed to be corrected by the buffer or preamp are now gone.Parts-Express.com:*Dayton DFFC-0.47 0.47uF 400V By-Pass Capacitor | polypropylene capacitor polypropylene PAC PA low pass foil film and foil dayton capacitor caps cap ac 47uf .47uf
1. A case
2. Wire (approximately how much?)
3. Binding posts
4. Power cable w/ amp and wall connections
Is construction this simple?
What's a good source for these?
