Help
0 Members and 1 Guest are viewing this topic. Read 1241 times.
Derockster
Help
« on: 15 Jan 2010, 11:23 pm »
Hey guys,not sure if this is the correct forum for this question.If it's not then feel free to relocate it.I've recently downloaded Exact Audio Copy and can't seem to get it open.Any help by way of suggestions would be greatly appreciated.Regards Cleaton
Niteshade
    • Niteshade Audio
Re: Help
« Reply #1 on: 15 Jan 2010, 11:32 pm »
Did you get it in a zip format, self extracting .EXE or something else?
Derockster
Re: Help
« Reply #2 on: 16 Jan 2010, 01:51 am »
It was in a zip format.
Niteshade
    • Niteshade Audio
Re: Help
« Reply #3 on: 16 Jan 2010, 02:37 pm »
I don't know which version of Windows you are using. Try right clicking on the file and see if you get some extracting options.
Another idea: http://www.winzip.com/index.htm
Sometimes people like using Winzip better. Get the trial version.
