Hum with Video Input
0 Members and 1 Guest are viewing this topic. Read 1056 times.
Stu Pitt
« on: 15 Jan 2010, 06:44 pm »
I know this was covered pretty recently, but I can't find it anywhere...
I have my TV connected from its RCA audio outs to my B60.  I hear a good amount of hum through the speakers when on this input, and a lower but still noticable amount through the other inputs (except the phono input).
Its not the TV or the interconnects - a new TV does the same thing and interconnects were swapped to confirm.  The hum hasn't increased or decreased.
The TV being on or off makes no difference.
I unplugged the cable from the TV and it was gone in every input.  I don't use a cable box with the TV in my listening room.
By process of elimination, I'm pretty confident the problem is the cable wire.
Now for the $64k question -
What can I do to get rid of the hum?  I don't have enough inputs on the B60 to directly connect everything I have going into the TV and my music sources and I can't use the optical out from the TV.  And I refuse to give the cable company another dime to 'rent' another cable box and remote.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Hum with Video Input
« Reply #1 on: 15 Jan 2010, 06:49 pm »
About half way down the page:
http://www.jensen-transformers.com/iso_vid.html
Model VRD-1FF
Cable TV RF isolator
james
ian.ameline
« Reply #2 on: 15 Jan 2010, 06:58 pm »
Yep - A ground loop from the cable-TV connection is very common problem -- solved completely with a simple and inexpensive isolation transformer like the one James links to. You'll loose a couple of db on the cable video signal (a bit less than what you'd lose with a 2 way splitter), but otherwise no difference.
Stu Pitt
« Reply #3 on: 15 Jan 2010, 08:03 pm »
Thank you, gentlemen.
John Casler
« Reply #4 on: 15 Jan 2010, 08:56 pm »
Google for PICO MACOM TSI-2400 Coaxial Voltage Isolator
Less expensive ($9.95) and as effective
This will work with CABLE ONLY , not DISH or DIRECT TV.
