How can I tell if either the Denon 2900 or 5900 have DPL2?
0 Members and 1 Guest are viewing this topic. Read 1220 times.
EDS_
Denon, in their product outlines, says each player has "built in Dolby Digital".
I'd like to know if this means that Dolby Pro Logic II is included or not. How can I find out? Anyone know?
Ferdi
« Reply #1 on: 21 Jan 2004, 05:11 pm »
Hi, to the best of my knowledge, this means that the digital multichannel format Dolby Digital is supported. If a multichannel track is presented on a DVD (or even on a CD, I guess), it is properly decoded and sent to the appropriate L/R/C/LR/RR/SW channel.
DPL2 is for turning stereo tracks into surround sound by guessing in a smart way what should go where.
Neither the 2900 or 5900 will have this feature. I have the 2900 but can check the manual again if you want.
I gladly give my opinion for a better one.
EDS_
« Reply #2 on: 21 Jan 2004, 05:18 pm »
Quote from: Ferdi
Yes. I'd like to find a universal player with DPL2 so that I can play CDs into 5.1.
I think I'm out of luck unless I buy a pre-pro that has DPL2.
Thanks-
Rob Babcock
« Reply #3 on: 21 Jan 2004, 09:26 pm »
Yeah, I think you're outta luck, there.  That has to be done in the processor.
« Reply #4 on: 22 Jan 2004, 12:22 pm »
Through in an input on one of these and you'd have a full processor  :lol:
