0 Members and 1 Guest are viewing this topic. Read 31166 times.
I plan on running my HT2-TLs with 2 UPA-1's to start. 350 into 4 ohms should be suffcient. The price is slightly less than the XPA-2, and there are some pretty good owner "reviews" on the emo boards.
Wanna talk amps this weekend before you buy?
I have seen a few people driving with XPA-2, but not with XPA-3. So wondering if there's a big differences there. Recently, i've changed from Denon amp to Emotiva UMC-1. Although i can find better clarity and smooth-ness, i still find it lacking the 'sweet sexy' feel. It also seems like there is not sufficient bass at certain tracks, so could this be due to insufficient power? I can't seems to get the 'kick' in bassy tracks.
Hi All I sincerely appreciate all the responses to my queries so far. I use my system more as HT, but i do appreciate good music once a while. My current system is as below:SongTower + SongCenter4 x Mirage Omnisat as surroundSVS PC12+ subEmotiva UMC-1 (driven by XPA-3 for 3 front)Previously i was using Denon AVR-2309 receiver before i switch over to UMC1. As mentioned, i do find improved clarity and smoothless with the switch, but i still feel this is far from the potential for the ST to shine. How should i make my setup sound nicer for stereo music? I am now thinking to offload my XPA3, and replace with a XPA5 for center+4 surround. Will look for another 2 channel amp to drive the ST (After taking suggestions from brothers here) Thanks all once again. Much appreciated.
Thanks guys i will keep that in mind. Can you point me to the treatment thread you are referring to? What about preamp? Any to recommend?
. . . and not all that unusual, your choice of music, artists, and recording quality.
The secret to economically improving your audio system is pretty simple. Identify and replace the worse case problem in the chain first.
For example, the desire for "better bass" usually send people looking for bigger speakers and/or a subwoofer. However, if your amp, preamp, and/or DAC do not actually play back clean and powerful deep bass well, then all the subwoofers in the world won't help much.
If changing interconnect cables or speaker wires makes a obvious difference, this should be a red flag that something in your system is excessively load sensitive, not a good thing. Just having a decent audio tech armed with a sine/square wave generator, load bank, and scope can help you root out many easy to identify problems for a lot lower cost that just starting to replace things or cables randomly.
What is your price range?
