SOLD: CI Audio VAC-1 High Current Power Supply for $149
0 Members and 1 Guest are viewing this topic. Read 830 times.
5ilver5urfer
Upgrade the Performance of any CI Audio Product with the VAC-1 Outboard Power Supply!
Barely used. I don’t need it any longer and It’s now past the return date.
Save yourself some $$ and go for the easiest upgrade decision ever.
The VAC-1 is the perfect upgrade for any CI Audio product. It provides marked improvements in bass definition, noise floor, dynamic range and soundstaging. The VAC-1 improves on the stock "wall wart" power supply by providing higher current power delivery and cleaner power. Upgrading to the VAC-1 is simply a 'no-brainer!' Highly recommended.
Manufacturer information:
The VAC-1 is the perfect upgrade for CI Audio source components. The upgrade yields improved bass definition, dynamics and noise performance. IEC type AC socket for use with aftermarket power cords. AC input and output cables included.
The VAC-1 is compatible with the following CI Audio products:
  • VDA-1 24bit / 96k Digital/Analog Converter
    VDA-2 24bit / 192k Digital/Analog Converter
    VPP-1 MM / MC Phono Preamplifier
    VHP-1 Headphone Amplifier
    VHP-2 Headphone Amplifier
SPECIFICATIONS:
AC Input Voltage: 120VAC
Output Voltage: 14VAC @ 1.44 amps
Accessories: IEC Type AC cable, AC output cable
Dimensions: 4.40"w x 2.65"h x 4.40"d
[/s]
« Last Edit: 3 Feb 2010, 07:40 pm by 5ilver5urfer »
