Fixing cracked MDF baffle...
0 Members and 1 Guest are viewing this topic. Read 1965 times.
cujobob
« on: 11 Jan 2010, 05:06 am »
I'll try to get a picture up shortly.
I ordered a pair of Response Audio's demo GR Research OB7s last year...and they arrived severely cracked thanks to UPS....right on the baffle, inbetween the lower midrange woofer.
I have a replacement driver ready to go, but what can I do to stabilize the MDF and repair it?
WGH
Re: Fixing cracked MDF baffle...
« Reply #1 on: 11 Jan 2010, 06:01 am »
Tape one side with clear packaging or masking tape then carefully fill the crack with a thin penetrating epoxy like West System. I use the 105/205 resin and hardener. The resulting repair will be stronger than the surrounding MDF. Sand the repair smooth, repaint and the speakers will be better than new.
Wayne
Christof
« Reply #2 on: 12 Jan 2010, 04:04 am »
Wayne
+2....I pick it up locally at West Marine store....you should have one near by you in MI....you might want to pick up a small G/Flex kit which has everything you need including thickener.
Hey Wayne, are you using G/5 +pigment for knots or 105/205 or both?
WGH
« Reply #3 on: 12 Jan 2010, 04:39 am »
Howdy Chris - I start with the 105/205 tinted with black paint pigment to fill cracks and glue knots. Mesquite is an open pored wood so I try to do most of my filling before final milling because the black epoxy also fills in the surrounding pores and leaves a dark shadow around the cracks and knots. Once the wood is milled and sanded there are always more cracks and voids to be filled so I switch to G5 which sets up in 3 minutes so it doesn't soak in as much which means the dark shadow is not very deep and can be sanded out.
Wayne
Christof
« Reply #4 on: 13 Jan 2010, 02:25 am »
Wayne
Cool, Thanks  :thumb:
