White Noise Audio transformers for AKSA amps?
massappeal85
« on: 23 Jan 2003, 12:56 am »
http://www.wnaudio.com/trans.html
Heres a little info on them from their catalog. Tell me if they could work with say, an AKSA 55?
"White Noise toroidal mains transformers are quite simply the best available for powering solid state equipment. There are currently three types available. The 500VA, 2x50V ac transformer is suitable for driving either one or two high power amplifiers such as the MOS250.  The 300VA, 2x35V ac transformer will drive power supplies yielding full output from up to four DVA100s or two MOS125s. The 30VA, 2x25V ac transformer is intended to produce either ±24V or ±15V dc for line level circuitry in conjunction with a suitable power supply. This transformer is included as standard with our cascode power supply. Other voltages and ratings are available on special order. Transformers are normally shipped separately by parcel post at a cost of £9 per 500VA, £6 per 300VA, and £3 per 30VA, transformer (in addition to the normal P&P charge if other items are ordered at the same time).
30  VA, 2 x 25 V,  0.60 A secondaries (74mm D x 30mm H)         £20.00
300 VA, 2 x 35 V, 4.28 A secondaries (113mm D x 54mm H)         £40.00
500 VA, 2 x 50 V, 5.00 A secondaries (146mm D x 65mm H)         £60.00"
