Good, Cheap 2-channel system recommendations?
0 Members and 1 Guest are viewing this topic. Read 8111 times.
Doublej
Re: Good, Cheap 2-channel system recommendations?
« Reply #20 on: 14 Jan 2010, 02:03 am »
TEAC CR-H227 Hi-Fi Mini Component System is a great little unit. It is showing up on Amazon at $230. As an alternative consider this Onkyo setup for less than $250.
http://www.onkyousa.com/model.cfm?m=CS-325&class=Audiosys&p=i
charmerci
« Reply #21 on: 15 Jan 2010, 11:16 am »
Tell your buddy to go to wallyworld,get a $200.00 all in one player and pocket the rest of the cash.The wife will probably be happier than a pig in slop and so will he.
 :thumb:
Plus - for that little extra security, he can also take her out to a not-too-expensive dinner too! ("I found a good deal on this so I can take you out for dinner!")
Niteshade
    • Niteshade Audio
« Reply #22 on: 10 Feb 2010, 02:00 pm »
You have to look at this: http://cgi.ebay.com/KLH-KL-2400-2-Channel-Stereo-Tuner-Receiver_W0QQitemZ260549940018QQcmdZViewItemQQptZReceivers_Tuners?hash=item3ca9fc9332
I have one of these beasts and it's remarkable! The preamp isn't that good, BUT- it has jumpers for amp in and pre-out!  :eyebrows:
The amp is very,very good. It uses a 300VA toroid. The circuit is a basic push-pull, sturdy reliable one rated for 100 watts/channel. I went inside and disconnected the front panel controls so the display remains black. (Easy to do- just unplug it.)
The anodized solid aluminum face plate & knobs are nifty for such a cheap thing. It's something to try and awesome for under $50.00. The amp is very efficient too. It has a respons eof 20-20,000hz and a THD rating of something like .01%.
Known issues: Sometimes the speaker protection relay needs replacing/burnishing on this model.
NOTE: Unlike most cheap receivers, this one has a removable bottom access plate! It's built quite nicely.
