Ready Acoustic Chameleon Frames
0 Members and 1 Guest are viewing this topic. Read 1972 times.
Stylus
« on: 6 Jan 2010, 07:10 pm »
I ordered a few of these for my first few panels that I am building and have a few questions.
Since there will be no rigid internal frame, what is the best way to go about mounting the panels to the wall?  I was thinking about mounting some 1x1's first to create a small air gap behind the panels, and then mounting the panels to the 1x1's.
How should I attach the hooks to the panels?
arthurs
Re: Ready Acoustic Chameleon Frames
« Reply #1 on: 6 Jan 2010, 07:32 pm »
These friggin rule!  http://rotofast.com/
Big Red Machine
« Reply #2 on: 6 Jan 2010, 08:51 pm »
I like an additional air gap behind the panel myself.  I added a 1 inch piece to the frame and just hung them on finishing nails.
Stylus
« Reply #3 on: 6 Jan 2010, 09:06 pm »
Did you just push them onto the finishing nails?  Or did you use some sort of hook?
TRM
« Reply #4 on: 10 Jan 2010, 05:48 pm »
good call, I'm going to do that with my ATS frames.
