BP26 DAC questions
0 Members and 1 Guest are viewing this topic. Read 1649 times.
mitcho
BP26 DAC questions
« on: 6 Jan 2010, 06:55 pm »
thanks
« Last Edit: 9 Jan 2010, 03:11 am by mitcho »
alexone
Re: BP26 DAC questions
« Reply #1 on: 9 Jan 2010, 08:25 pm »
you are welcome, mitcho :thumb:!
al.
mitcho
« Reply #2 on: 10 Jan 2010, 12:18 am »
what my question was-   is there a lot of difference between the installed/ internal DAC in the BP26 vs the BDA-1?  If so, is it a lot of difference or minor?   I had thought of getting a BP26 DAC vs. my other preamp and my BDA-1?
Ron D
« Reply #3 on: 10 Jan 2010, 02:55 am »
A buddy of mine had both and his comment on the dac within the BP26 was "It has this sound which I would describe as "more detail but hollow and less substance". I am not 100% sure but I think the DAC in the preamp may be a single chip (CS43122) as opposed to a fully balanced dual chip set in the BDA-1 which are CS4398, same chip that is in the BCD-1 but as I note I am not sure.
I have a BDA-1 on hand right now and it is impressive even with a not too fancy optical nor a very good coax cable in play.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 12 Jan 2010, 01:22 pm »
Ron - correct - the chip in the BDA-1 is dual mono and is capable of 192/24 whereas the chip in the BP26 is a single ship limited to 96/24.
james
mitcho
« Reply #5 on: 12 Jan 2010, 01:24 pm »
I should probably stay the way I have it now.   thanks
