Damn, I really like this except for one thing: Directv HD DVR surround sound. i did not realize someone made a multi-channel pre.
You might want to consider the McCormack Audio MAP-1. This is a very nice multi-channel pre amp with no processing capability, which you do not need, since the decoding will be handled by your Oppo. Spearit Sound (I have no connection) has a demo for sale at $1595. http://www.spearitsound.com/mccormack/map1.aspGary
I will be using both the internal DACs of each unit, and those of the source devices(Squeezebox Duet and Oppo BDP-83). I am figuring my first upgrade for 2 channel will be an external DAC(AVA Ultra/DacMagic/Benchmark Dac 1 are ones I want to demo) so I want to not only compare the different DAC's, but also the analog of the Denon, Arcam and Anthem.
You may or may not know this, but one thing to look out for is that most, if not all, AVR's route all of the inputs through their internal DAC's.
You may or may not know this, but one thing to look out for is that most, if not all, AVR's route all of the inputs through their internal DAC's. They do this because all the tone and room controls are done in software. For the analog signals to have tone controls and bass management they have to go through an internal ADC to convert the signals into digital to be processed. To test the DAC's of the Duet and Oppo, they need to be run directly into your amp (Rotel?) unless you have a 2 channel preamp.Bob
