0 Members and 1 Guest are viewing this topic. Read 20955 times.
I heard the Anthem with the HT-3's and I really really liked what I heard. The Salks played both loud and clear as a bell. I haven't had the opportunity to hear the other 2 preamps with anything. Cheers,Robin
This might come across as 2 channel snobbery, but I have yet to hear a pre/pro that sounds as good as a decent dedicated preamp, let alone a good one.I think the better path (as suggested by Nuance) is to get a dedicated 2 channel preamp with HT bypass capabilities and continue using your 3808 (which is a very nice unit).This will provide better sonics than going with any of the pre/pro options.George
But there lies the problem, I do not find the Denon to be up to snuff for movies, either. It is good, but not good enough for what I expect. I want to upgrade both music and movie sound, not just one or the other.An external amp will be ordered before the preamp, and this could bring the home theater side of the Denon up to snuff, however I am guessing it will not.
Hmmm...what don't you find up to snuff?I use a 3808 (as do a few of my friends with very nice HT's) in my HT with five SongTowers and think it performs quite well. While I am not as picky about the performance of my HT as my 2 channel setup, I still wanted to have a very pleasurable experience and the Denon delivers.Now, I do use external amplification to drive the SongTowers, so I am not using the internal amps of the Denon. Personally, I think the weakest part of pretty much all mid-level AVR's is the amplification. With relatively cheap amplification options out there (ATI, Emotiva, Parasound, Rotel, etc...), I strongly urge you to try an external amp before changing out the 3808.George
What external amps are you using?I actually had won an ATI 1806 off of ebay for $560. Of course, after winning it that cheap, the seller found out that it is 'not working anymore' and refunded me my money, which in reality means for $560 he will just keep it an use it.
You might want to consider the McCormack Audio MAP-1. This is a very nice multi-channel pre amp with no processing capability, which you do not need, since the decoding will be handled by your Oppo. Spearit Sound (I have no connection) has a demo for sale at $1595. http://www.spearitsound.com/mccormack/map1.aspGary
ATI 1506
They keeping up okay? I'm considering a pair of 1504's.
