0 Members and 1 Guest are viewing this topic. Read 14209 times.
That is one nice system you have there but only one gallery picture? Come one man, take more pix and post 'em
I notice that you have your annies facing straight ahead with no toe in.
I've never heard LAMM amps but I'm betting they are killer with the VR5s
Jon,That is one nice system you have there but only one gallery picture? Come one man, take more pix and post 'em. I notice that you have your annies facing straight ahead with no toe in. Have you tried toeing them in any at all and if so, what did it do to your imaging and soundstage? I've never heard LAMM amps but I'm betting they are killer with the VR5s.
es347:Why not try Pearson's "rule of thirds?"Mark
HiGavin.... are you going to start to build a dedicated listening room.
I continue to move the speakers and it seems that the best spot so far is with the baffles about 6' from the front wall and about 3.5' from the sides. This is giving me a big soundstage, good imaging although not quite as holographic as when the speakers were further from the front wall, and it has lessened the mid bass hump at 80-100 hz. I may go with some larger corner bass traps to see if that will allow moving them back out further into the room. The holographic image that produces is quite alluring.Gavin
