0 Members and 1 Guest are viewing this topic. Read 6479 times.
I'll throw my 2 cents in here at well, and vote on the side of woofer replacement. When you over drove the woofers you probably overheated the voice coils, and when that happens the varnish covering the coil wire often bubbles up, which then makes the tolerance in the gap too narrow or tight. Any subsequent heating of the voice coils (just from normal use) can cause scraping and nasty sounds. So the noises you were hearing might not have even been related to the ripped loose spiders.Neil
Thank you, everyone who replied.It sounds like the consensus is woofer replacement. Since new woofers appear to be more affordable than I thought they would, I have to agree. Now, I just have to acquire them.Someone mentioned checking for tweeter damage. What's the best way to do that?
Quote from: indygreg on 31 Dec 2009, 07:01 pmThank you, everyone who replied.It sounds like the consensus is woofer replacement. Since new woofers appear to be more affordable than I thought they would, I have to agree. Now, I just have to acquire them.Someone mentioned checking for tweeter damage. What's the best way to do that?The only reliable way to do it is to take a FR measurement. But short of that, if there is a problem with the tweeter, you will likely know it. If the top end is missing or is edgy sounding, it may be work checking them out. But usually, if they are going to fail, they will either not work at all or the sound quality in the treble will be terrible. Once you get the woofer situation addressed, just listen to the speakers in a CASUAL manner (if you over-analyze things, you will convince yourself you are hearing all kinds of problems). If there is a problem with the tweeter, you will know it.- Jim
