0 Members and 1 Guest are viewing this topic. Read 4506 times.
Sometimes I listen with the waveguides on. Sometimes I listen with the waveguides off. Without the waveguides they are ever so slightly brighter and with slightly better dimensionality at "the" listening spot. With the guides on, they look better, the drivers are more protected, and the imaging is pretty good over a much wider area. I do not adjust the L-pads when shifting between the two, although there is, of course, a slight attenuation when the guides are on.
Is there still a choice between waveguides and non-waveguides when ordering new speakers?If I remember correctly, there was a crossover change to adapt to the waveguide, so it'sjust not a matter of removing the waveguides if you don't like them.
I actually also listen with and without waveguides but I did some measuring and with the waveguides on my RM30s there is a serious off axis drop in response as opposed to without the waveguides. This is the opposite from what people have reported.
A simple HORN is a directivity device and it (like a megaphone) directs and controls the directivity (directions that the sound will be controlled to).
A horn amplifies a signal and controls dispersion.
I'd be interested in the physics of it causing amplification.
The new SOTA RM 50 does not have front radiating waveguides.How will that effect other speakers in the VMPS line?
