question for shane
thxultra
question for shane
« on: 17 Jan 2004, 05:51 pm »
Have been using the version 20 software for the sp.1 for a while now and have just tried to activate the subwoofer with by-pass and it's not working. I haven't tried this before so dont know if it's a fault or v20 is to blame, any ideas
  • The Demo is Everything!
    • http://www.bryston.com
question for shane
« Reply #1 on: 18 Jan 2004, 02:20 pm »
Hi THX,
James here,
Hit Code - red light comes on  - then punch in 060 - LCD screen on SP1 should show 'bypass sub - yes'.
Do it again to disengage 'sub bypass'
james
thxultra
question for shane
« Reply #2 on: 18 Jan 2004, 02:28 pm »
Hi James
is that not for the 1.7 , theirs no code button or numbers on the sp1 remote.In the manual it says to press cd and music button together but nothing happens.The only other diffrence is i'm running v20 software which shane sent me to try out.
Could you also have  a look at a couple of questions i've posted below this one about a muting problem and a ticking noise
mark
question for shane
« Reply #3 on: 18 Jan 2004, 02:41 pm »
Hi - yes you are right - sorry the code was for SP1.7.
james
