Seeking subwoofer recommendations/advice
0 Members and 1 Guest are viewing this topic. Read 3616 times.
2gumby2
« on: 14 Dec 2009, 10:49 am »
I've decided to add a couple of subwoofers to one of my 2-channel systems and wondered about the experiences others may have had with some of the subs I am considering. I am limited in floor space and would prefer a subwoofer taking up no more than 15" X 15" floorspace. So far, I am considering the Sunfire HRS series, Definitive Technology Supercube II, Elemental Designs A3S with 2 band parametric EQ, and one of the SV Sound cylinder subs. If I go with SV Sound, I will only be able to get one due to my space limitations. A Hi-Fi dealer that I have been dealing with for more than 30 years recommends the Definitive Technology. He uses Definitive Technology subs with his Magnepans in his personal 2-channel system and loves them. I am open to suggestions.
Marbles
Re: Seeking subwoofer recommendations/advice
« Reply #1 on: 14 Dec 2009, 02:02 pm »
IMO, none of the above...
Do a search for Rhythmik Servo subs
Lots of info, esp. in the GR Research circle.
JohnR
« Reply #2 on: 14 Dec 2009, 05:39 pm »
Hey, this is cheap and cheerful, max system cost $1000. Good question but shithouse recommendations (in that context).
srb
« Reply #3 on: 14 Dec 2009, 06:57 pm »
I guess cheap and cheerful means less than $1K per pair.
No, Cheap and Cheerful HiFi means, as JohnR reminds us, less than $1K for an entire system - source, amplification and speakers.  The topic/question doesn't really even belong in this particular circle.
konut
« Reply #4 on: 14 Dec 2009, 08:20 pm »
The best inexpensive subs I know of are the active servo(low distortion) subs from Yamaha.
http://www.jr.com/yamaha/pe/YAM_YSTSW216BL/
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115128
Those are the 2 that seem to fit your dimensional requirements at the lowest prices I could find. While not the last word in extension or output, a few of these in the room should yield a satisfactory presentation.
Marbles
« Reply #5 on: 14 Dec 2009, 09:01 pm »
The Sunfire HRS are MSRP from $699USD - $899
You can get the Rythmik for less than that.
Guess I didn't know of the $1000 total system cost, so disregard my advice...
srb
« Reply #6 on: 14 Dec 2009, 09:20 pm »
To be fair, the OP was soliciting thoughts about the contenders he had narrowed it down to (and even other suggestions), and the first three models he listed retail from $700 to $1800 a pair.
So some of the responses are certainly in line with that.  I just thought the topic would have been moved to a more appropriate circle, as I get the feeling that he is looking for something better than a pair of $100 Yamaha subs.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #7 on: 14 Dec 2009, 09:25 pm »
As you have rightfully pointed out, it's pretty confusing, so I retracted my previous recommendations and previous post. Let's just leave it at that.
Anand.
2gumby2
« Reply #8 on: 15 Dec 2009, 10:51 am »
O.K., so it seems I posted in the wrong circle. What would be the most appropriate Circle to post this question in?
In the past, I built a couple of Rythmic subs in 2 cubic foot sealed boxes. Sound quality was fine, but they just didn't have the ouput I was looking for for the Sludge metal and pipe organ music that I listen to on occasion. Brian Ding was a great guy to deal with though so I can recommend his company.
