Help w/ T8 Volume Control using Harmony Remote
0 Members and 1 Guest are viewing this topic. Read 1318 times.
mchuckp
« on: 14 Dec 2009, 05:00 am »
Just got my new T8 (and love it so far).  However, having an issue.  It goes in my main TV set and I like to use a Harmony remote.  I didn't see it in the default manufacturers so I added it myself and taught it volume and mute.  Well it works except when I push Volume Up or Down, it just keeps going!!!  I push volume and the knob just keeps on turning.  Obviously this won't cut it.
Anyone else using a Harmony with their AVA preamps?  Any solutions?  Can't figure out why it does it.  Hope there is a workaround.
Thanks.
srb
Re: Help w/ T8 Volume Control using Harmony Remote
« Reply #1 on: 14 Dec 2009, 05:19 am »
When you say you "added it myself taught it", I assume you mean the remote was in the learning mode and you had the two remotes head to head.  Try it again, but with just a single quick press of the volume as opposed to holding the button down until the remote says OK.
mchuckp
« Reply #2 on: 14 Dec 2009, 06:22 am »
Thanks for the advice.  I went through the learning again and pressed it as fast as humanly possible.  The software claimed it read it.  I then updated the remote again and still got the same result.  :scratch:
I'm wondering if I should delete the device completely and try it again versus just "relearning".  I'll try this tomorrow night unless someone else has a better idea before then.
