0 Members and 1 Guest are viewing this topic. Read 10768 times.
When I asked a similar question, DougS suggested the YAMAHA YST SW315, 200w servo-sub, available via eBay for around $205, new:http://cgi.ebay.com/NEW-YAMAHA-YST-SW315-HOME-THEATER-POWERED-SUBWOOFER-NR_W0QQitemZ200416358863QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item2ea9bef1cfChad
They seem to be pretty popular for low priced surplus components of decent quality. Check here:http://www.apexjr.com/http://www.diyaudio.com/forums/apex-jr/
doug s, I'm just cursious what other subs you've heard to compare to the Yamahas. I never would've guessed Yamaha made good subwoofers.BTW, have you heard a Rythmik sub? I'm still itching to hear one, but can't afford it yet.
I tried searching for the dual 8" model you mentioned, but when I search for yst-sw215, I only find a smaller, single 8" downfiring version of the sw315.
yes, that's cuz it's been discontinued. which is why i recommend the sw315. as i said, you will have to be wery patient to find a matched pair of the yst-sw215's... when i got mine, i bought one, then found a second one a couple months later...doug s.
It's not that I can't find one... just that the model yst-sw215 is not the sub you referred to, but a single 8" downfiring version: http://www.amazon.com/Yamaha-YST-SW215PN-Powered-Subwoofer-Piano/dp/B000MT7RW8/ref=sr_1_1?ie=UTF8&s=electronics&qid=1265303765&sr=8-1http://www.yamaha.com/yec/products/productdetail.html?CNTID=200486&CTID=5003300So I'm not sure which model the dual 8" front firing version is...unless Yamaha just reused that model number for a different product.
AV123 is running a special again. Dual MFW-15's for $899.Best,Anand.
