I just purchase a pair of B&W 602's speakers, needles to say that I am not very happy with them and the performance that I usually like is not there. Since they are considered bookshelf speakers I can't ask for much so I need a good subwoofer to enhance the sound quality of it. Any good recommendations? I looked into Partsexpress.com and they have some "Dayton" model really inexspensive but you usually get what you pay for. So I'm going to look into pre own equipment, any good recommendations would be appreciated. I may not last long with these B&W's
I had 602 S2s and thought they sucked. The bass was weak and the midrange into the lower treble was thin and way too forward/edgy. I thought the Totem Arros I replaced the 602s with were much more full-bodied and to my taste, even though they don't go much lower than the B&Ws and have somewhat significant dynamic and spl limitations.
It is certainly possible that the B&W 602's are not to the OP's (or other's) taste, but I wanted to address your post with two thoughts: In direct comparison, the B&W 602 S3 has a fuller midrange and smoother treble than the S2 version. The B&W 602 is a $600 speaker and the Totem Arro is a $1200 speaker. But I tend to agree, if the speaker placement is optimized and the room itself is not problematic, then no subwoofer will appreciably change the response and character of the speaker. Steve
