Dodd Buffer
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: Dodd Buffer
« Reply #20 on: 29 Dec 2009, 08:51 pm »
Crap.... does the remote only turn it on and off???
jtwrace
    • TIPP YouTube Channel
Re: Dodd Buffer
« Reply #21 on: 29 Dec 2009, 08:53 pm »
only adjusts volume (up and down) is what it says
TRADERXFAN
    • GALLERY
Re: Dodd Buffer
« Reply #22 on: 29 Dec 2009, 08:53 pm »
Oh, I thought it was saying On and off!  :oops:
jtwrace
Re: Dodd Buffer
« Reply #23 on: 29 Dec 2009, 08:55 pm »
Did the tubes give you any trouble?
What battery are you going to use?
Hopefully mine is on my porch....
-Tony
No trouble with tubes.
I'm going to use this battery:  http://www.power-sonic.com/site/doc/prod/96.pdf
I'm sure yours it waiting for you...
jtwrace
Re: Dodd Buffer
« Reply #24 on: 29 Dec 2009, 08:57 pm »
 :rotflmao:
I must admit you got me scared and I jumped up to double check.
TrungT
Re: Dodd Buffer
« Reply #25 on: 29 Dec 2009, 09:00 pm »
Any Picture?
 :drool:
jtwrace
Re: Dodd Buffer
« Reply #26 on: 29 Dec 2009, 09:01 pm »
Any Picture?
 :drool:
Look at page one
TrungT
Re: Dodd Buffer
« Reply #27 on: 29 Dec 2009, 09:03 pm »
Dohhh  :oops:
Looking great. :drool:
dBe
    • PI audio group, LLC
Re: Dodd Buffer
« Reply #28 on: 29 Dec 2009, 09:38 pm »
I just got it out and took pictures and installed the tubes.  I will report back when I get it up and running.
I'm thinking that mine will be here in Albuquerque on Friday  aa
Dave
TrungT
Re: Dodd Buffer
« Reply #29 on: 29 Dec 2009, 10:43 pm »
Dave
Is your battery and charger show up yet?
dBe
Re: Dodd Buffer
« Reply #30 on: 29 Dec 2009, 10:48 pm »
Dave
Not yet.  I'll check the tracker later.
Dave
jtwrace
Re: Dodd Buffer
« Reply #31 on: 29 Dec 2009, 10:58 pm »
Dohhh  :oops:
No need to drool...you can have one too.  Just give Gary a call.  See how easy?   :)
TrungT
Re: Dodd Buffer
« Reply #32 on: 29 Dec 2009, 11:02 pm »
Mine is on Gary list, but the battery is fully charged.  :D
TrungT
Re: Dodd Buffer
« Reply #33 on: 30 Dec 2009, 06:06 am »
Hope everyone have the battery fully charged.  :D
A friendly remind: Do not use any kind power supply to run your battery powered tube Dodd gears, have to be a fully charged 12v battery.
Let me know if you want a good deal AGM battery for a great deal (if they still have it)
TRADERXFAN
    • GALLERY
Re: Dodd Buffer
« Reply #34 on: 30 Dec 2009, 06:36 am »
I actually emailed Gary to ask about using a power supply to break in the amp.
I have one from parts express that specified at 12v for 2amps....
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=120-536
Why doesn't this work?
-Tony
TrungT
Re: Dodd Buffer
« Reply #35 on: 30 Dec 2009, 07:26 am »
Tony
I don't know why it won't work, I don't really know all the technical detail, but I heard Gary himself talk about that, Please let me know what Gary reply to your email.
ctviggen
Re: Dodd Buffer
« Reply #36 on: 30 Dec 2009, 12:06 pm »
-Tony
There's no reason that shouldn't work.  Assuming, that is, you can get or create the right connector.  I looked on the Dodd website but don't see a picture of the back of the buffer.
jtwrace
Re: Dodd Buffer
« Reply #37 on: 30 Dec 2009, 01:05 pm »
-Tony
you can see the PowerCon connector on page one on my pictures
http://www.neutrik.com/fl/en/audio/204_390365502/powerCON_20_Amp_productlist.aspx
TRADERXFAN
    • GALLERY
Re: Dodd Buffer
« Reply #38 on: 30 Dec 2009, 04:22 pm »
Well, the other end is terminated with moderately sized alligator clips.
And Gary said yes it will work ok on this power supply. Not optimal for performance. But I just want to run the thing for a while without the battery and recharging, etc...
So can't wait to get it going tonight.
jtwrace
Re: Dodd Buffer
« Reply #39 on: 30 Dec 2009, 04:37 pm »
Here is the battery / charger that I'll be using.  If I like this Buffer as much as I hope, I will then make a aluminum box with a power on / off selector for the battery and charger.
