0 Members and 1 Guest are viewing this topic. Read 15168 times.
am curious how much the everest sub goes for. & i'd be interested in hearing about a plug-n-play sub w/one tumult & two 18" pr's, or a plug-n-play kit, if the price were right...
But I am not sure based on displacement that a 15" driver alone can compete with a sub that has a 12", 15" and a 15" passive radiator in a bigger cabinet. That says to me: simple physical laws of displacement.
PORTED as I referred to it is prone to PORT noise and do not usually sound controlled enough for me. The VMPS as I read it has no hole. It is vented via mass-loaded PR. No way to make port noise. Additionally the mass loading makes sense. Control the Q, control the response, eliminate the boom.
I just got the overwhelming feeling this thread has in fact turned into a one-sided advert for Tumult and RAD products. Unless the maker of VMPS would jump in and defend his products against this one-sided thread. This time it is not one-sided due to my opinions.
John,The subs were sealed, with an LT circuit, and front firing.
The mass-loaded slot-loaded PR subbass VMPS uses is a good compromise technically while offering unique flexibility from the practical standpoint.
...Just to give you guys some idea of the quality of bass that the Tumult is capable of I'll share with you some info. I got from a customer who bought two custom-built Tumult based subs from me. He said they easily bested any dual Aerial Acoustics SW12's or Revel B15's that he'd heard. He also said they were as good as, if not better than, the single Velodyne HGS-18 that he'd heard. The rest of his music/HT system was all Aerial Acoustics speakers....
IIRC, the Fb was 18Hz and Qtc=.6.
