0 Members and 1 Guest are viewing this topic. Read 3474 times.
Ok - the B100 would work fine with the speakers you mentioned so the only advantage of the separates would be the flexibility in integrating a bigger amp later on.james
The DAC in the B100 is limited to 96/24 resolution so as long as you do not see yourself going to higher bit rates later on then there is no need to go for the external DAC.james
Quote from: James Tanner on 7 Dec 2009, 07:46 pmOk - the B100 would work fine with the speakers you mentioned so the only advantage of the separates would be the flexibility in integrating a bigger amp later on.jamesThe B100 could be used as a pre-amp if he needed a bigger amp in the future.Quote from: James Tanner on 7 Dec 2009, 07:46 pmThe DAC in the B100 is limited to 96/24 resolution so as long as you do not see yourself going to higher bit rates later on then there is no need to go for the external DAC.jamesDoes the internal DAC upsample to 96/24, or does it accept up to 96/24 and leave lower bit rates alone? I'm assuming the answer would be the same for the B60 as it is for the B100.
