0 Members and 3 Guests are viewing this topic. Read 404036 times.
Bill would you elaborate on the above....not sure what you're referring to ?
To those who have the tranquility, would you think a tube or a ss amp would go best with it?
Tube. IMHO.
Bill, rpf,thanks for your feedback. I am currently using a very lean and dry sounding amp. If I am hearing correctly, the tranquility is lean as well. Not sure if the system will end up sounding analytical and lose musciality?
I believe that The source should be as true, transparent, neutral and uncolored as possible ... it seems that Tranquility is just that ... the source should be agnostic of tube or solid state in front of it ... it should just deliver the goods ...
While I seriously appreciate the liquidity and analogue sound of the tranquility (reading from reviews) but it looks like the tranquility is facing some serious competition from the pdx as described by bill.
I find myself in the same situation - being drawn to toobs ... and I find the best place for me to have tubes is in the Pre section ... they provide slight warmth and glow ... without sacrificing dynamics, drive and transparency ... But for each person they have to find what works for them ... apparently Ayon and others are doing good things with tube output stages in their source ...
Wow, thanks for all the comments and making a newbie feel welcomed! Yikes I am torn between the pdx and the tranquility! While I seriously appreciate the liquidity and analogue sound of the tranquility (reading from reviews) but it looks like the tranquility is facing some serious competition from the pdx as described by bill. My amps are ss and thereotically, using a valve front end would help with the lean ness of the amp. Not that I do not like the neutral sound, but it may be too much! Ha, what an exciting yet frustating time to be in!
In my experience the Tranquility does not add warmth to a system. The Tranquility is not sterile or bright sounding and to me (and others) has an analog (turntable) sounding quality to it.
