GOM again
lkosova
    • http://www.AutomatedHomeandBusiness.com
GOM again
« on: 14 Jan 2004, 08:14 pm »
I asked a question before about using acoustic transparent covering like GOM Guildford of Maine that is used to cover speakers in Home theaters/media rooms.
If I decided to do that so it would seemlessly match a decor could you just use that to make the products vs what you are using now???
Yes I would send you a link and sample material first???
This might be a good avenue for you guys anyway to have your products match the room. The customer would just have to supply their own material and with GOM the 701 series has lots of choices and most designers of home theaters etc use this material because of the acosutic properties
Larry
8thnerve
GOM again
« Reply #1 on: 15 Jan 2004, 03:48 pm »
If we did, the cost would be higher and there would be a 2 to 3 week lead time.  Contact me directly if you would like to discuss.
Best Regards,
Nathan Loyer
Eighth Nerve
lkosova
GOM again
« Reply #2 on: 15 Jan 2004, 04:31 pm »
I am not ready yet but just investigating all my options if I need this time of solution.
Larry
I figured it would cost more.
