cold start-up
0 Members and 1 Guest are viewing this topic. Read 1571 times.
Bill
cold start-up
« on: 3 Dec 2009, 03:00 pm »
I have a couple of pieces of equipment (tube phono stage and SS amp) that haven't been fired up for at least a year or more. Should I take any precautions when starting up? I've heard of thermistors but have no idea on how to implement them. Any ideas out there?
sts9fan
Re: cold start-up
« Reply #1 on: 3 Dec 2009, 03:51 pm »
not sure you would use those.  I know "I" use then on line with the ac input.  You would be better off with a variac.
ctviggen
Re: cold start-up
« Reply #2 on: 3 Dec 2009, 04:59 pm »
I say just turn them on.  What's the big deal?
rollo
  • Rollo Audio Consulting -
Re: cold start-up
« Reply #3 on: 3 Dec 2009, 05:02 pm »
No problem whatsoever, turn them on.
charles
Pez
Re: cold start-up
« Reply #4 on: 3 Dec 2009, 05:20 pm »
I've turned on pieces of equipment that have been unused for way longer than that with no problem. The only time a variac is really necessary is if you are dealing with a really old piece of equipment you are not 100% sure works or you're firing up a DIY project for the first time or after mods. Now depending on who you ask the tubes may have a few days or so before it sounds good because the tubes need a little time to come back to their full potential after a long period of no use.
*Scotty*
Re: cold start-up
« Reply #5 on: 3 Dec 2009, 05:27 pm »
Depending on the age of the storage caps in the power supply and the rail voltage you might be better off bringing it up to voltage slowly with a variac. In the case of the high voltage supplies in an analogue oscilloscope that does not see constant usage on the bench it is a good idea to exercise the power supply by turning the scope on for 24hrs once a month. This increases the life of the storage caps as they are partially formed up and not being hit with high voltage in a completely unformed condition.
Scotty
richidoo
Re: cold start-up
« Reply #6 on: 4 Dec 2009, 12:51 am »
They will need to burn in again before they sound good.
