Pace Car Mod Fun
0 Members and 1 Guest are viewing this topic. Read 10134 times.
serengetiplains
Re: Pace Car Mod Fun
« Reply #20 on: 29 Nov 2009, 07:48 pm »
I didn't replace the caps but merely added an extra few uFs on each of the four sections.  These are stacking a little high, of course, so I plan to plunk them all in their own box.  The additional uFs are providing more bass, which tells me I'll probably hit desired EQ on my headphones @ about 2X original cap values.
audioengr
« Reply #21 on: 29 Nov 2009, 08:20 pm »
Thanks for the feedback.  Make sure you direct some kind of fan across the board or it will get too hot.
Steve N.
serengetiplains
« Reply #22 on: 4 Dec 2009, 05:58 pm »
I have to reiterate, what a surprising and welcome change this upgrade brought.  This is the type of change one hopes for in an upgrade, a change that gets to root subtleties.  It reminds me of Linn's motto that changes in the source are the most fundamental.
audioengr
« Reply #23 on: 4 Dec 2009, 07:30 pm »
Have you tried any of the Hynes 3-pin shunt regulators?
Steve N.
serengetiplains
« Reply #24 on: 4 Dec 2009, 10:16 pm »
I haven't, but they look to have the same specs as his larger SR1 shunt supplies.  Perhaps Paul can speak to their sonics.
Paul Hynes
    • http://www.paulhynesdesign.com
« Reply #25 on: 5 Dec 2009, 12:37 pm »
Hi serengetiplains,
The Z17 type mini shunt regs use the same regulator circuit topology as the SR1M, same ultra-high speed, fast settling, low noise, ultra-wide bandwidth error amp. The current source used in the SR1M is a different topology due to the high power requirements. Overall performance is very similar both technically and sonically aside from the obvious difference in power capability.
Regards
Paul
jimiles
« Reply #26 on: 27 Jan 2010, 06:16 am »
Question for Steve;
I already have and love Paul's SR3-12 and I was blown away by Serengeti's mod  :drool:  but I'm not quite that brave.
If I sent my PaceCar 2 in for the UltraClock upgrade, would you be willing to investigate swapping that 7808 regulator for one of Paul's 3-pin shunt regulators?
If the correct answer is to wait for your next-gen PaceCar, then I can appreciate that, too.
Jake
audioengr
« Reply #27 on: 27 Jan 2010, 07:27 pm »
Question for Steve;
Jake
This is exactly what I was thinking.  I'm also planning to try some in the Overdrive as well.
As a matter of fact, I already have a number of sample regulators on order from Paul, but I have not heard from him for a while.....
Steve N.
