SP2 LPCM Rate Limit setting in OPPO BD Player
0 Members and 1 Guest are viewing this topic. Read 1507 times.
JohnnyB
« on: 22 Nov 2009, 02:16 pm »
James,
There is a setting in the OPPO for LPCM rate limit: 48K, 96K or 192K.  Higher values result in better audio quality by using higher sampling rates and frequesny response.
Does the SP2 support the higher LPCM rate limits?  If so, which is the correct setting?
Thanks, JohnnyB
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2 LPCM Rate Limit setting in OPPO BD Player
« Reply #1 on: 22 Nov 2009, 04:50 pm »
James,
Thanks, JohnnyB
SP2 will support 96/24
