A way to get a 'line out' of the IA7 Integrated?
0 Members and 1 Guest are viewing this topic. Read 1742 times.
joshcloud9
« on: 20 Nov 2009, 11:42 pm »
Is there a way to configure a 'line out' of the IA7 V1 Integrated amp?
I am using the pre-outs and it works but not nearly as well as a proper line out would for my application (wireless speakers for a rest room!)
Is there a way to get a line out, I'd be happy to give up an input to use for a line out...any ideas anyone?
rustydoglim
    • www.nuprimeaudio.com
Re: A way to get a 'line out' of the IA7 Integrated?
« Reply #1 on: 24 Nov 2009, 12:25 pm »
What do you mean not nearly as well? I guess you would have to use a RCA to 3.5mm cable?
joshcloud9
« Reply #2 on: 24 Nov 2009, 03:36 pm »
hello Jason,
I should have given more detail;
I want to use a standard line out so I can use my main speakers at the same time as having a line out to my aux wireless speakers control box.
(If I didn't want to use my main speakers at the same time I could turn "booster" off and use the Pre-out)
I am using the Pre-out but I have to turn up the volume too much to get a satisfactory level for the aux speakers.
A standard source line out gives the required level...for instance if I hook up my FM tuner directly to the wirelss speakers it works great!
Josh
rustydoglim
« Reply #3 on: 25 Nov 2009, 08:22 am »
I think the preout can be programmed by Nuforce to fix at 0db (12 o'clock volume level) and that should be pretty loud.  I see, you need the max volume from the line out.
