0 Members and 1 Guest are viewing this topic. Read 121741 times.
I was thinking waterfall plots... combination of impulse and frequency response.. This might reveal what folks are commenting on w.r.t bass response and clarity/imaging. Not sure really - just a thought.- Doug
Doug,Those all look like single speaker measurements, and are a great tool for selecting a speaker to purchase. But for setting speakers in a room, I think you would need some sort of measurement of both speakers operating at the same time.Steve
I was thinking of in-room response of the entire system from the listening position(s). Things like smoothness of the bass response, dropouts at certain frequencies, and decay times at different frequencies would be evident there. It wouldn't tell you anything about imaging per se (no problem doing that by ear), but it could help to sort out the basics and perhaps indicate a "preferable" set of parameters that could be achieved by anyone with the aid of those types of measurements - sort of an extension of the kinds of things Floyd Toole talks about in his book. - Doug
I would like to jump in from an acoustics perspective, although everything I'm about to state has been said in some form or another...maybe just not in same words.There are some metrics that can look on paper like a great listening space such as:- Frequency Response +/- 6dB or better- Decay time from 50Hz to 1KHz within 3:1 ratio (some say 2:1)- No significant modal ringing (goes hand in hand with first two points)- The amplitude of room reflections is 15 dB down from direct signal. Note: this is a sticky point as a dedicated listening room by it's nature puts the listening beyond the critical distance where room energy is more significant than direct sound...but this is a way to factor discrete reflections that can cause image shift through the use of Energy verses Time analysis.None of those can tell you what the room sounds like. Nothing can factor the way that transient signals propogate in the room which is a huge factor in the perceived quality of sound. In low frequency regions you have room/modal issues and then you have boundary coupling and interference. These can be identified and modified by speaker/listening position. This is really the main "trick" to the Master Set. That deliberate process with "good ears" can certainly put a specific speaker in a very good location. Add the right room treatments and the results can be more "universal" for that same room. At high resolution analysis (1/12th octave or better) boundary interference nulls can look horrifying in a freq response graph. But the human ear is designed to hear through (to a certain extent) narrow nulls. We are much more affected by sharp peaks.As for imaging...too many variables in speaker/room relationship to comment on if just a speaker set could optimize imaging without some acoustical remedy.What I admire about this thread is the awareness of this factor. It's really such a primary part to the whole listening equation, easily as important as any component. An analogy that comes to mind is one can own and string up a beautiful acoustic guitar, but you're not making music until you learn the notes/chords. Speaker placement is the same as learning the notes/chords.
Nope, none. I'll be posting my own pictures soon enough.
Jake- Such propagandazing. Have you no shame? That's only Tim's semi happy face.
Jim - I AM smiling! LOL. I'm in Brazil for a couple of weeks and only just got to where I have a decent Internet connection. I'm glad Jon sent the picture to Jake and I'm glad Jake posted it because I did want everyone to see the dramatic difference in speaker location. The only thing more dramatic is the improvement in sound in ALL regards.Best luck to all and happy listening.
