96khz not working through spdif
0 Members and 1 Guest are viewing this topic. Read 1427 times.
polar316
« on: 14 Nov 2009, 10:13 pm »
i have my cambridge audio dacmagic connected via optical to my imac. when i set my MIDI Audio settings to 96khz, i just get crazy fuzz even at minimal volumes with no signal being sent to the dac. any suggestions?
thanks,
Zach
Crimson
Re: 96khz not working through spdif
« Reply #1 on: 15 Nov 2009, 01:34 pm »
A few questions: Are you upsampling or using native 24/96 material? Are you restarting iTunes after changing the AudioMidi settings? Does everything work fine at 16/44.1? I've done 24/96 via the toslink output on an iMac with no issues.
polar316
« Reply #2 on: 16 Nov 2009, 09:50 pm »
Yes I was using 24/96 files, and I tried restarting iTunes. It also does work on 44.1 and 48. It had nothing to do with iTunes though, as the fuzz was coming out even with iTunes closed.
Crimson
« Reply #3 on: 17 Nov 2009, 12:38 am »
So you get the noise with nothing playing. Could be the dac. Any way you can get your hands on another 24/96-capable dac?
ted_b
« Reply #4 on: 17 Nov 2009, 12:53 am »
Stupid questions but what the heck:
Does your DAC show 96k on it's sample rate light?
Are you sure you have only toslink/optical connected, not both optical and coax (manual says they fight each other and don't work)?
polar316
« Reply #5 on: 17 Nov 2009, 01:27 am »
its the only thing plugged in, and yes when i set the MIDI Audio on my mac to 96, the DAC shows 96 as well.
