0 Members and 1 Guest are viewing this topic. Read 54267 times.
Depends what you mean by "loading" on the back.
perhaps you can screw the sides on, making it airtight with some kind of temporary gasket or something - you get to try it out and listen for a week or so before you 'finalize' it with glue.
I might have a spare set of phase plugs from a pair of FE206E which were damaged in shipping (the drivers, not the phase plugs). They are buried in the closet, assuming they really exist...Hi Teflon, I don't have great links to Ron Clark's writings but as John says, he posted a lot at the fullrange forum back when that was the "it" place, and he also posted at a couple others which I found by Googling for the Austin. You can definitely piece together the whole story. Short version is that he's an engineer and he loves horns. When work was slow, he built a cab at his work, placed sensors into different parts, took pressure measurements, and gradually refined his math. He has certain ideas about wavefronts, e.g. that you want to preserve the energy to reduce losses due to friction, and you want the wave to stay or at least return to a certain shape.His last known project is a design called the Houston, which he (I think) says he gave up on (but he would also hint that he'd take it out of the drawer now and then, and revisit it). I read a description of it as one FE206E that has "three actions," and I could never understand how this works but the driver faces up, points into a deflector and divides into two paths. One path returns sound to the user (off the deflector). The third action is a BLH. I could not quite picture the second action. I would love to see a diagram if anyone knows of one.Ron, my apologies if my summary is way off base! My recap is surely flawed.
PS, and off the subject, after hearing these for the first time the other night, now I'd like to think more about trying something like these as front Mains for an HT, with a pr of Lowther Ace style cabs for the surrounds, with the Fostex's too...Might be interesting, but I got no idea where to find a 5.1 SET amp....
Steve's building block method?http://www.decware.com/newsite/zkit2.htm
