Batteries for Dodd power amps
0 Members and 1 Guest are viewing this topic. Read 6277 times.
jtwrace
    • TIPP YouTube Channel
Re: Batteries for Dodd power amps
« Reply #20 on: 30 Nov 2009, 05:04 pm »
that's 200 AH of battery though.
Danny Richie
« Reply #21 on: 30 Nov 2009, 05:09 pm »
Yeah, but the two of them together cost about the same as one power cord that I use on everything else I have. So a pair of those batteries and the charger seems pretty low cost to me.
jtwrace
« Reply #22 on: 30 Nov 2009, 05:13 pm »
Danny
Yes, I'm not talking cost...it's minimal compared to other "stuff".  I'm just saying that with 200 AH of battery, one shouldn't have an issue with a buffer / amp.
I'm just going to have a buffer.  I think that 20 AH should work for a couple of days max.  right?
Danny Richie
« Reply #23 on: 30 Nov 2009, 05:50 pm »
Just for the buffer alone that will power it just fine.
I did a little tube rolling in my buffer and settled on some Amperex, Orange label, 7308's, and man this combo is sounding great!
jtwrace
« Reply #24 on: 30 Nov 2009, 05:55 pm »
I will look into those..what else did you try?
Now I just need to get my buffer.  hint hint gary
Danny Richie
« Reply #25 on: 30 Nov 2009, 06:07 pm »
The others that were pretty good were some 6H1N's, some JJ's.
gld
    • http://doddaudio@live.net
« Reply #26 on: 30 Nov 2009, 06:59 pm »
Hey guys, I just did some measurements on the current draw of the buffer. I found that with normal 6DJ8 and equivalent tubes the thing uses 400 ma, if you use Russian 6N1P's it uses 700 ma. So with that in mind and we all know batteries are not the same, we can probably get 2 hours or so. So you can easily calculate how much battery you need for your application. Around 2 hours on each amp-hour of battery. :thumb:
Gary
jtwrace
« Reply #27 on: 30 Nov 2009, 07:40 pm »
Gary
That's great to know.  Thanks Gary.   :thumb:
