3 BPC configurations, please help!!
0 Members and 1 Guest are viewing this topic. Read 2718 times.
webjanne
« on: 9 Nov 2009, 09:17 pm »
Hi there!
I just received a pair of used Super 3 BPC without any manual. Can anyone explain how the different configurations (i.e. 4, 8 or 16 ohm - dipole, bipole, monopole etc) are achieved?
erik
bprice2
Re: 3 BPC configurations, please help!!
« Reply #1 on: 9 Nov 2009, 09:28 pm »
Did the speakers come with the jumper wires?
webjanne
« Reply #2 on: 9 Nov 2009, 09:45 pm »
There were no jumper wires, only 2 "pieces of gold" to connect the upper and lower pair of connections...
//erik
bprice2
« Reply #3 on: 10 Nov 2009, 01:17 am »
//erik
Check out this thread...especially Louis' second post.
EDIT: Sorry, on second read the thread I pointed to was not very instructive.
What I know about my Super 3 Bipoles is if I connect the binding posts with the jumpers from + to + and - to -, the speaker is in bipole config.  If I cross the jumpers to the binding posts, then the speaker is in dipole config. Remove the jumpers and the speaker is in monopole config.
I believe bipole and dipole modes are 4 Ohm and monopole is 8 Ohm.
rajacat
  • Washington State
« Reply #4 on: 10 Nov 2009, 03:14 am »
There is also a 16 ohm bipole mode. One jumper is used to connect the positive posts. Only one jumper is used. It connects one negative post diagonally to one positive post. The remaining posts are connected to their respective speaker wires.
-Roy
« Last Edit: 10 Nov 2009, 05:11 am by rajacat »
webjanne
« Reply #5 on: 11 Nov 2009, 03:58 pm »
rajacat and bprice2:  Thanks for your replies!
//erik
rajacat
  • Washington State
« Reply #6 on: 11 Nov 2009, 04:18 pm »
//erik
erik,
If my reply wasn't that clear just give Louis at Omega Audio a call. I'm sure that he would send you a copy of the manual.
-Roy
Louis O
« Reply #7 on: 13 Nov 2009, 12:38 am »
Hi webjanne,
Please call me at 203.847.2800 and I will explain.
You will need the jumpers.
Louis
