1st measurement of room. . .the journey begins (with pics)
0 Members and 1 Guest are viewing this topic. Read 7062 times.
youngho
Re: 1st measurement of room. . .the journey begins (with pics)
« Reply #20 on: 25 Nov 2009, 03:53 pm »
Hi, I was wondering what you meant about the backing (plywood panel?) and how you used the FSK, i.e. facing is toward the room or away from the room, etc? Thanks
pjchappy
« Reply #21 on: 25 Nov 2009, 06:06 pm »
Sorry about that.  By backing, I do mean FSK.  All panels w/ FSK have the FSK side facing the wall -- 2 on the front wall; 2 behind the listening position; and the panel on the floor and the one I can put in front of the TV or in front of the TV stand have the FSK too, which I have (so far) placed facing the floor and TV.
So, in simpler terms, the FSK faces away from the room.
The 2 corner boxes and the 2 at the first reflection points on the side walls do not have FSK.
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
« Reply #22 on: 25 Nov 2009, 10:33 pm »
I got 192 sq. ft. of 703 (without backing) and 48 sq. ft. of 703 (with backing) for $214.
In the Boston area, OC 703 w/o FSK is $86.XX for a "case" of (12) 2'X4'X2" sheets.
pjchappy
« Reply #23 on: 25 Nov 2009, 10:38 pm »
Which is about $12 more than I paid.   :wink:
oneinthepipe
  • Trainee
« Reply #24 on: 26 Nov 2009, 05:54 am »
Everything is more expensive in Boston!  :lol:
Stylus
« Reply #25 on: 26 Nov 2009, 03:31 pm »
Try California, mine was a little over a hundred!  Still a lot cheaper than online considering shipping though!
pjchappy
« Reply #26 on: 26 Nov 2009, 10:13 pm »
Here are some pics. . .
Behind listening position:
Front right (obviously, still need to cover the 1' x 4' x 6" bass trap):
Right:
Front left:
Left:
Above window - Eight Nerve seem(directly in between speakers; will replace with two 1' x 4' x 4" panels):
Right corner - Eight Nerve triangle (have in all 4 corners):
From listening position:
Construction details (the other panels have 2" holes on all 4-sides, versus the slits on the bass traps):
oneinthepipe
  • Trainee
« Reply #27 on: 27 Nov 2009, 01:05 am »
Your room looks very good, pjchappy.  Nice job.
Stylus
« Reply #28 on: 29 Nov 2009, 03:20 pm »
Well done, looks good!  :thumb:
pjchappy
« Reply #29 on: 29 Nov 2009, 09:06 pm »
Thanks!  Just need to take an iron to the corner folds and maybe down the middle.  Will build 2 more over the next few days (two 1' x 4' x 4").
Won't be able to take measurements until later this week, as I found out the disc I need for my laptop is on backorder.  If the disc doesn't work, I'll need a new HD.
pjchappy
« Reply #30 on: 5 Dec 2009, 07:07 am »
Well, I'm still without my laptop, so I can't take measurements, yet.  However, the backup disc shipped and if it arrives tomorrow, I will FINALLY be able to take new measurements.  (well, that is if I don't actually need a new HD)
This weekend, I will hopefully get to the last 2 panels (two 1' x 4' x 4") for above the window, also.  Too much stuff came up, though. . .so I have a feeling that won't happen.
