0 Members and 1 Guest are viewing this topic. Read 2767 times.
I have a stepson who continually uses my AKSA gear without permission. I was thinking I could remove the on/off toggle switch on the GK-1, and replace it with a keylock. Then when I turn it off, I can take the key with me.Any ideas on a suitable product?
The problems are when he brings friends over, who call my system "mad". I think it is a compliment. Then they want to put some rapping person thing called "50 Cent" on. Then they want to "crank" it. I think that means turn it up. If I had JBL's or such, it would be okay. But the 7 watt Diatones? Hmm, there could be a problem.
Jaycar (in Sydney, Australia) has a key switch that will handle 240 volts. I think I will go down that road. The Redgum with a switch does look cool. Particularly with the key ring.
