Older 4B - UnBalanced Mono Operation - Turn Off Noise
0 Members and 1 Guest are viewing this topic. Read 1313 times.
peter002
I have an older 4B for my SubWoofer and I get Turn Off Noise from the amp when it is in Mono operation (unbalanced). It powers down for a second then a loud static type sound starts up for another second.
The amp turns on without a sound and there is no noise when used in Stereo.
Any thoughts??
Thanks ....Peter
  • The Demo is Everything!
    • http://www.bryston.com
Re: Older 4B - UnBalanced Mono Operation - Turn Off Noise
« Reply #1 on: 6 Nov 2009, 10:28 pm »
Any thoughts??
Thanks ....Peter
Hi Peter,
It is just a capacitor turn off discharge - the newer amps have a relay to prevent it. It will not cause any harm as it is very low level.
james
peter002
« Reply #2 on: 9 Nov 2009, 01:11 pm »
Thanks James,
You are correct - it is a low level issue. It just had me bothered.
This is the first amplifier that has done my 24'' Harley Woofer justice - great product.
Now I know what a "sound floor" is.
.....Peter
