0 Members and 1 Guest are viewing this topic. Read 21055 times.
Separates are always better. All high performance systems are separates.
Well then, maybe you should ask the many, many companies that build only separates what their reasoning is? Then I will start laughing. Also, people who make statements like that have no clue about the engineering aspects of the product. Integrated amps will never equal their counterpart separates in most respects. LOLWayner
I guess the topic was one or the other. I picked my preference and now I'm the bad ass. Maybe it's just stupid to ask a question that has one or the other answer. Your response is very questionable as well.WaynerMaybe you should ask the fine companies that make integrated amps if they like being referred to as something other than "high performance", to use your words. If I were to pick my dream system...sure, they would consist of separates, but that wasn't the question. Maybe you don't literally mean what you said, but when you make sweeping generalizations you are more likely to come off as offensive and condescending (to a number of AC manufacturers, to boot...Response Audio and Vista make fine products, for example). Rather than ask the OP what kind of budget they have, or trying to elicit any information that might help lead the person towards some useful information, you got up on a high horse. I think realizing that you took a condescending tone in both your posts would be a fine place to start. Now I understand my comments might be a little harsh, but if you don't see any problems with saying "All high performance systems are separates", then we'll just have to agree to disagree. But hey, what do I know...I'm from the northeast, so I'm lacking in manners and class compared to my mid-west counterparts.
Separates are always better. The real problem is noise and the difficulty shielding the fragile preamp section from the powerful amplifier section. Another advantage of separates is realized at upgrade time, if more power is required, all you need is a new amp. All high performance systems are separates.Wayner
