Picture Food Needed
  • The Demo is Everything!
    • http://www.bryston.com
Re: Picture Food Needed
« Reply #960 on: 13 Nov 2011, 07:30 pm »
...isn't the BDP-1 more an ear opener? :green:
al.
I stand corrected :duh:
James
Robert D
« Reply #961 on: 13 Nov 2011, 09:49 pm »
:thumb: :thumb: a truly nice bithday present!
al.
Thank you Al
bjski
« Reply #962 on: 29 Nov 2011, 05:39 am »
My small room in the basement.Yes,lots of wires. My surround sound is upstairs.
SoundGame
« Reply #963 on: 29 Nov 2011, 12:54 pm »
bjski - nice setup.  Your room doesn't look too small - how big is it?
Those speakers look very interesting - what brand/model are they.  I notice they use Heil/AMT tweeters.  At least one of them looks very much like the ELAC Jet III tweeter.  How do you find the Bryston works with those tweeters?
bjski
« Reply #964 on: 29 Nov 2011, 03:18 pm »
The speakers are Legacy Focus SE. Many of the high end magazines are just coming out with their reviews.(absolute sound)
I had Infinity Epsilons before which were also ribbons. The Infinity's had an outboard control unit for the bass. I drove the Infinity's with 2 4bst. I destroyed one EMIT and could not find a replacement so I decided it was time for new speakers. I liked the sound of ribbon's so I decided to stick with those.  All I can say is Legacy's sound great. The Legacy's have more subtleties than the Infinity's and the Foucus SE bass seems more controlled and deeper. This might be attributed to replacing the 4BST amps with the new 7BSST/2. I also changed my interconnects to Morrow Grand reference 6 and the speaker wire to the new Bryston cable. The Bryston cable is bi-wired. The sensitivity is 95db at 4 ohm's which mean the 7BSST/2 just barely get warm.
Prior to my Infinity's I had the Thiel 3.6.
Not sure who makes the ribbons but the were influenced by Oskar Heil.
SoundGame
« Reply #965 on: 29 Nov 2011, 03:26 pm »
Heil / AMT tweeters are quite different then typical ribbon tweeters but share the same extension, air and speed.  They work in a very different manner than typical ribbons, expelling air in an accordian-like fashion.  I'm looking forward to trying out a pair of ELAC 247s soon.
Warren_Buff
« Reply #966 on: 29 Nov 2011, 10:57 pm »
I am getting an error (!) when trying to upload the linked picture:
http://www.catbank.jp/event/2008/karuizawa/main/t8.jpg
Any idea of why ?  May the file be too large?
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #967 on: 30 Nov 2011, 10:51 am »
Seems to work fine once done correctly...
spinner
« Reply #968 on: 30 Nov 2011, 11:49 pm »
 Now that JBL is the real deal . :thumb:
Warren_Buff
« Reply #969 on: 1 Dec 2011, 02:12 pm »
It definitively is.
The below link shows JBL DD66000 Everest driven by 4 times Bryston 7B SST2 for the woofers and the Bryston 4B SST2 for the top.
http://www.audioheritage.org/vbulletin/showthread.php?31733-3-ways-to-climb-Everest
Warren_Buff
« Reply #970 on: 1 Dec 2011, 02:14 pm »
How did you upload it ?
I get this message when pressing "Upload image":
<?xml version="1.0" encoding="UTF-8"?>
-<smf><upload status="OK">aHR0cDovL3d3dy5hdWRpb2NpcmNsZS5jb20vaW5 kZXgucGhwP2FjdGlvbj1nYWxsZXJ5O3NhPXZpZX c7aWQ9NjkwOTU=</upload></smf>
Anonamemouse
« Reply #971 on: 1 Dec 2011, 03:03 pm »
There is no need to upload. all I did was add something to your image link
What I added:
Code: [Select]
[img]http://www.catbank.jp/event/2008/karuizawa/main/t8.jpg[/img]
When you click on the insert image button
You can either upload (option 1) an image to the forum, or (option 2) link to an external image
To upload an image it has to be stored locally on your own computer, it is not possible to upload an image that is online. For an online image you have the choice to either save it to your own computer first and then upload it to the forum, or hotlink to the url of the image directly. I usually go for the second option, you just paste the url of the image there and the tag will be made for you.
Warren_Buff
« Reply #972 on: 3 Dec 2011, 12:28 am »
larevoj
« Reply #973 on: 3 Dec 2011, 01:43 am »
 :o That is some SERIOUS Bryston amplification!!!  :thumb:
Interestingly only a 4BSST2 for the tweets...I know of folks actually uses tubes for tweets and SS for woofers.
SoundGame
« Reply #974 on: 3 Dec 2011, 05:08 am »
I think someone needs a bigger room...and perhaps some bigger pipes...LOL!
Warren_Buff
« Reply #975 on: 3 Dec 2011, 09:53 am »
Warren_Buff
« Reply #976 on: 3 Dec 2011, 10:26 am »
The Sonus Faber (also known as Sonus Faber Fenice):
Warren_Buff
Warren_Buff
« Reply #978 on: 4 Dec 2011, 09:41 pm »
Greg Timbers, Chief Development Engineer at Harman, is the man in the middle.
spinner
« Reply #979 on: 4 Dec 2011, 09:59 pm »
 So this is Mr. JBL.  :lol:
