EPOS 3C Speaker Pair
0 Members and 1 Guest are viewing this topic. Read 1029 times.
paularthur
« on: 3 Nov 2009, 05:37 am »
Offered by P.A.U.L. an Authorized EPOS Dealer
http://www.precisionaudioonline.com/PAUL.html
SALE Pair Price $389.  Retail $698
SOLD AS STEREO PAIR ONLY
FULL MANUFACTURER WARRANTY
SHOWROOM DEMO
ALL SALES FINAL
The Epos ELS 3C utilizes the same drive units as the ELS 3 and is therefore ideally matched for use in a home cinema application.  The design improves on the Critically Acclaimed ELS 3 in the areas of sweetness, bass extension and dynamics.
Featuring a 25mm metal dome tweeter with neodymium magnet, together with two 5 1/2 woofers, they use a new die cast aluminum chassis with a cone and surround similar to that being used in the M5 woofer. The Epos logo is embossed on the tweeter faceplate.
In designing this speaker, EPOS has introduced an unusual and acoustically advanced crossover which reduces the coloration when two mid/bass units are in close proximity to each other.
The Epos ELS 3C is ideal for use with other ELS products in a home cinema application.
Technical Information:
Power Handling: 100 Watts Max
Frequency Response: 65Hz - 20kHz
Impedance: 8 Ohms Nominal
Sensitivity: 87dB/1 watt/1 meter
Amplifier Compatibility: 25 - 100 Watt
Configuration: Center Channel
Weight: 8.8kg
Size W x H x D (mm): 510 x 174 x 195
Finish Type: Vinyl wrap
Finish: Light cherry
4% surcharge for credit cards.  Personal check must clear prior to shipment.  Insured shipping paid by customer.
